Ga door naar hoofdinhoud
Dell G3 15 3579 RAM Replacement
Wat je nodig hebt
  1. Dell G3 15 3579  RAM Replacement, RAM: stap 1, afbeelding 1 van 1
    • Make sure the laptop is off.
    • Lay the laptop on its front so the bottom is facing up.
  2. Dell G3 15 3579  RAM Replacement: stap 2, afbeelding 1 van 1
    • Use the Phillips #0 to remove the eight screws (M2.5x6) on the bottom of the laptop.
    • Use the Phillips #0 to loosen the two captive screws (M2.5).
  3. Dell G3 15 3579  RAM Replacement: stap 3, afbeelding 1 van 3 Dell G3 15 3579  RAM Replacement: stap 3, afbeelding 2 van 3 Dell G3 15 3579  RAM Replacement: stap 3, afbeelding 3 van 3
    • Use your hands or an opening tool to gently pry the bottom panel off, starting from the left hinge.
    • Continue prying from the bottom to the right side of the back panel and lift it off.
  4. Dell G3 15 3579  RAM Replacement: stap 4, afbeelding 1 van 2 Dell G3 15 3579  RAM Replacement: stap 4, afbeelding 2 van 2
    • Gently unplug the battery connecter from the motherboard.
  5. Dell G3 15 3579  RAM Replacement: stap 5, afbeelding 1 van 3 Dell G3 15 3579  RAM Replacement: stap 5, afbeelding 2 van 3 Dell G3 15 3579  RAM Replacement: stap 5, afbeelding 3 van 3
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • After the RAM chip has popped up, pull it straight out of its socket.
  6. Dell G3 15 3579  RAM Replacement: stap 6, afbeelding 1 van 2 Dell G3 15 3579  RAM Replacement: stap 6, afbeelding 2 van 2
    • Gently align the new RAM with the tab on the slot.
    • Then slide it firmly into the slot at an angle and press the RAM down until it clicks into place.
    • If you do not hear the click, remove the RAM and reinstall it.
  7. Dell G3 15 3579  RAM Replacement: stap 7, afbeelding 1 van 1
    • Align the bottom cover with the slots of the laptop and snap it into place.
    • Tighten the two captive screws (M2.5) to secure the bottom cover.
    • Replace the eight screws (M2.5x6) to secure the bottom cover.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 97
Altijd: 5,642
