Ga door naar hoofdinhoud
Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Dell E193FPc Screen Replacement
Wat je nodig hebt
  1. Dell E193FPc Screen Replacement, Stand: stap 1, afbeelding 1 van 1
    • Lay the monitor screen-down so the back screws are exposed.
    • Remove the four 11.9 mm Phillips #2 screws securing the stand to the back of the monitor.
  2. Dell E193FPc Screen Replacement: stap 2, afbeelding 1 van 1
    • Gently lift and pull away the stand at a slight angle away from the monitor.
  3. Dell E193FPc Screen Replacement, Display Bezel: stap 3, afbeelding 1 van 2 Dell E193FPc Screen Replacement, Display Bezel: stap 3, afbeelding 2 van 2
    • Locate the two holes on the bottom of the monitor.
    • Insert a plastic opening tool or spudger into the holes and gently pry the plastic apart along the groove.
    • This task is much easier if two people pry simultaneously at each hole.
    • Continue prying along the entire edge of the monitor.
  4. Dell E193FPc Screen Replacement: stap 4, afbeelding 1 van 2 Dell E193FPc Screen Replacement: stap 4, afbeelding 2 van 2
    • When finished prying, the plastic will partially fall away from the rest of the monitor.
    • Do not try to fully remove the front frame yet. The frame is still attached to the buttons.
    • While holding the frames together, carefully flip the monitor over so it faces screen down.
    • Gently lift and remove remove the rear case from the monitor.
  5. Dell E193FPc Screen Replacement: stap 5, afbeelding 1 van 3 Dell E193FPc Screen Replacement: stap 5, afbeelding 2 van 3 Dell E193FPc Screen Replacement: stap 5, afbeelding 3 van 3
    • Locate the green interface button board.
    • Remove the three 9.71 mm Phillips #2 screws holding the interface button board to the display bezel.
    • Lift the monitor interior away from the front cover.
  6. Dell E193FPc Screen Replacement, Inverter Board: stap 6, afbeelding 1 van 3 Dell E193FPc Screen Replacement, Inverter Board: stap 6, afbeelding 2 van 3 Dell E193FPc Screen Replacement, Inverter Board: stap 6, afbeelding 3 van 3
    • With the monitor facing down, remove the two 5.81 mm Phillips #2 screws on the right side of the metal casing.
    • With the monitor still facing down, remove the two 5.81 mm Phillips #2 screws on the left side of the casing.
    • Do attempt to pull apart the casing. There are still wires holding the front and back together.
  7. Dell E193FPc Screen Replacement: stap 7, afbeelding 1 van 1
    • Using a 5 mm nut driver, unscrew the VGA port's mounting screws from the metal casing.
  8. Dell E193FPc Screen Replacement: stap 8, afbeelding 1 van 1
    • With the monitor facing down, gently lift the back case away from the rest of the monitor to expose the inverter board and mother board.
    • Recall that the casing is still held together by several wires. Do not attempt to fully remove the back casing.
  9. Dell E193FPc Screen Replacement: stap 9, afbeelding 1 van 2 Dell E193FPc Screen Replacement: stap 9, afbeelding 2 van 2
    • The inverter board is the smaller board in the corner.
    • Remove the three 7.69 mm Phillips #2 screws from the inverter board.
    • Remove the two 7.69 mm Phillips #2 grounding screws from the wire with the black connector.
    • Gently pull the inverter board away from the case. Note that the board is still connected to several components by wires.
  10. Dell E193FPc Screen Replacement: stap 10, afbeelding 1 van 2 Dell E193FPc Screen Replacement: stap 10, afbeelding 2 van 2
    • There is a wire connecting the motherboard to the inverter board. Squeeze both sides of the connector and pull to remove it from the socket.
    • There is another wire connecting the button board to the inverter board. Remove the second white wire connector.
    • A third wire connects the inverter board to the screen circuit board. Remove the black wire connector.
    • The inverter board can now be fully removed.
  11. Dell E193FPc Screen Replacement, Motherboard: stap 11, afbeelding 1 van 1
    • With the monitor facing down, remove the 5.84 mm Phillips #2 screw from the metal sheet.
    • You can now open the device up. Be careful, there are still wires attached to the motherboard.
  12. Dell E193FPc Screen Replacement: stap 12, afbeelding 1 van 1
    • With the monitor facing down, lift the back cover up and lay it face up, exposing the motherboard.
    • Remove the five 7.7 mm Phillips #2 screws from the motherboard.
  13. Dell E193FPc Screen Replacement: stap 13, afbeelding 1 van 2 Dell E193FPc Screen Replacement: stap 13, afbeelding 2 van 2
    • Squeeze the plastic prong in the middle of the motherboard with a metal tweezer, while gently prying the other side with the plastic prying tool.
    • Be careful when using the metal tweezers. Make sure you do not make contact with any part that contains metal, for it may still have a charge. Discharge all capacitors.
    • This is easiest when the monitor is positioned such that motherboard is beneath the metal casing.
  14. Dell E193FPc Screen Replacement: stap 14, afbeelding 1 van 2 Dell E193FPc Screen Replacement: stap 14, afbeelding 2 van 2
    • Remove the connector to the power outlet from the motherboard.
    • Remove the 4 connectors to the metal casing from the motherboard.
    • The motherboard can now be fully removed from the casing.
  15. Dell E193FPc Screen Replacement, Screen: stap 15, afbeelding 1 van 1
    • Remove the three 5.44 mm Phillips #00 screws on each side of the front of the metal casing.
  16. Dell E193FPc Screen Replacement: stap 16, afbeelding 1 van 3 Dell E193FPc Screen Replacement: stap 16, afbeelding 2 van 3 Dell E193FPc Screen Replacement: stap 16, afbeelding 3 van 3
    • Remove the three 3.94 mm Phillips #00 screws from the metal sheet along the front metal casing.
    • Gently pry the metal sheet away from the metal casing and lift off the metal piece.
  17. Dell E193FPc Screen Replacement: stap 17, afbeelding 1 van 1
    • Use a spudger to pry the screen casing away from the metal casing.
  18. Dell E193FPc Screen Replacement: stap 18, afbeelding 1 van 1
    • Gently pry the screen away from the metal casing.
    • The circuit board will still be connected to the metal casing. Do not rip out the screen to avoid damage to the board.
  19. Dell E193FPc Screen Replacement: stap 19, afbeelding 1 van 1
    • Squeeze the connector and remove the circuit board from the metal casing connector.
    • Use both hands to remove the circuit board. The screen is attached to the circuit board, so do not pull by the screen.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Mackenzie Keane
514 Reputatie
5 handleidingen geschreven
Cal Poly, Team 5-36, Amido Fall 2011 Lid van Cal Poly, Team 5-36, Amido Fall 2011
CPSU-AMIDO-F11S5G36
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 15
Altijd: 5,187
