Ga door naar hoofdinhoud
Dell E193FPc Interface Buttons Replacement
Wat je nodig hebt
  1. Dell E193FPc Interface Buttons Replacement, Stand: stap 1, afbeelding 1 van 1
    • Lay the monitor screen-down so the back screws are exposed.
    • Remove the four 11.9 mm Phillips #2 screws securing the stand to the back of the monitor.
  2. Dell E193FPc Interface Buttons Replacement: stap 2, afbeelding 1 van 1
    • Gently lift and pull away the stand at a slight angle away from the monitor.
  3. Dell E193FPc Interface Buttons Replacement, Display Bezel: stap 3, afbeelding 1 van 2 Dell E193FPc Interface Buttons Replacement, Display Bezel: stap 3, afbeelding 2 van 2
    • Locate the two holes on the bottom of the monitor.
    • Insert a plastic opening tool or spudger into the holes and gently pry the plastic apart along the groove.
    • This task is much easier if two people pry simultaneously at each hole.
    • Continue prying along the entire edge of the monitor.
  4. Dell E193FPc Interface Buttons Replacement: stap 4, afbeelding 1 van 2 Dell E193FPc Interface Buttons Replacement: stap 4, afbeelding 2 van 2
    • When finished prying, the plastic will partially fall away from the rest of the monitor.
    • Do not try to fully remove the front frame yet. The frame is still attached to the buttons.
    • While holding the frames together, carefully flip the monitor over so it faces screen down.
    • Gently lift and remove remove the rear case from the monitor.
  5. Dell E193FPc Interface Buttons Replacement: stap 5, afbeelding 1 van 3 Dell E193FPc Interface Buttons Replacement: stap 5, afbeelding 2 van 3 Dell E193FPc Interface Buttons Replacement: stap 5, afbeelding 3 van 3
    • Locate the green interface button board.
    • Remove the three 9.71 mm Phillips #2 screws holding the interface button board to the display bezel.
    • Lift the monitor interior away from the front cover.
  6. Dell E193FPc Interface Buttons Replacement, Interface Buttons: stap 6, afbeelding 1 van 1
    • Behind the front panel of the plastic cover lies the button strip.
    • Remove the buttons by gently pulling up on the strip.
    • You may have to pry the plastic strip up with a prying tool or spudger to remove it.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Charley Grove
98 Reputatie
1 Handleiding geschreven
Cal Poly, Team 5-36, Amido Fall 2011 Lid van Cal Poly, Team 5-36, Amido Fall 2011
CPSU-AMIDO-F11S5G36
4 Leden
12 handleidingen geschreven
Één opmerking
and then…?! you cant buy replacement buttons!! so now what?!
Sarah Barnes - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 2,169
