Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Locate the case cover latch on the back of the computer.
Using your index finger, slide and hold the cover latch down.
While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
Grab the edge of the panel and slide it away from the case until it is removed.
Locate the Video Card and the screw attached to the Video Card as shown in the picture.
Remove the 8.9 mm screw by using a Phillips #2 screw-driver.
Push down on the green clip located by the bottom right corner of the video card while simultaneously pulling the card up with your other hand.
Pull the remainder of the card up and out of it's slot.
9 andere personen hebben deze handleiding voltooid.
2 opmerkingen
I have a question - My dell dimension 4600 has lines going down the screen, ive tried 3 different monitors, reinstalling windows (reinstalling would have lines going down the screen, after installing all programs the system freezes up with lines going down the screen nothing else) ive tried system restore can someone tell me whats going on?
That sounds like either a GPU failure or internal Graphics failure. Have you checked thermal paste?
