Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Locate the case cover latch on the back of the computer.
Using your index finger, slide and hold the cover latch down.
While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
Grab the edge of the panel and slide it away from the case until it is removed.
Locate the Optical Drive by finding it externally on the case.
Press and hold the three levers located behind the front panel.
While holding the levers down, swing open the front panel.
Swing the front of the case open until it separates from the main case.
Locate the Drive 1 cable and where it is connected to the motherboard.
Grasp the end of the Drive 1 cable connected to the motherboard and firmly pull upwards until it is removed.
Locate the end of the Drive 1 cable connected to the optical drive.
Grasp the cable and pull firmly to disconnect it from the optical drive.
Locate the screw on the optical drive.
Remove the 7.7 mm screw by using a Phillips #2 screw-driver.
Remove the optical drive by sliding it out of the front of the case.
13 andere personen hebben deze handleiding voltooid.
