Ga door naar hoofdinhoud
Dell Chromebook 3180 LCD Replacement
Wat je nodig hebt
    • Open the chromebook until its completely flat on the table
    • Remove both the left and right hinge caps
    • Remove a total of 4 screws. One in each corner.
    • Use a plastic pry tool or blade and start in the top left corner or first left plastic ridge.
    • Lift up the LCD screen from within the LCD assembly frame.
    • On the back of the LCD screen, remove the tape and LCD connector
    • Attach the LCD connector
    • re-apply the tape to the LCD connector
    • Set the new LCD screen into the LCD assembly frame while matching up the screw ports in each corner
    • When installing the LCD bezel, look for the plastic hinge outlines on each side and match them up with the metal hinges on the chromebook.
    • Snap the LCD bezel in place until it is flush with the entire LCD assembly
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jon
3.921 Reputatie
22 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 11
Altijd: 798
