Ga door naar hoofdinhoud
Dell Chromebook 3100 2-in-1 Webcam Replacement
Wat je nodig hebt
  1. Dell Chromebook 3100 2-in-1 Webcam Replacement, Webcam: stap 1, afbeelding 1 van 1
    • Using a Phillips screw driver (PH1) remove the 9 (M2.5x4) screws holding the back cover
  2. Dell Chromebook 3100 2-in-1 Webcam Replacement: stap 2, afbeelding 1 van 1
    • Using a jimmy and remove the plastic covering to reveal internal hardware.
  3. Dell Chromebook 3100 2-in-1 Webcam Replacement: stap 3, afbeelding 1 van 1
    • Unplug the battery from the motherboard by pulling gently.
  4. Dell Chromebook 3100 2-in-1 Webcam Replacement: stap 4, afbeelding 1 van 1
    • Remove the single screw (M2x3).
    • Remove the bracket over the Wi-Fi and camera plugs.
  5. Dell Chromebook 3100 2-in-1 Webcam Replacement: stap 5, afbeelding 1 van 1
    • Unplug the now revealed camera and Wi-Fi antennas by gently pulling.
  6. Dell Chromebook 3100 2-in-1 Webcam Replacement: stap 6, afbeelding 1 van 1
    • Remove the single screw (M2x4).
    • Remove the bracket over the display cable.
  7. Dell Chromebook 3100 2-in-1 Webcam Replacement: stap 7, afbeelding 1 van 1
    • Lift the black tab and gently pull on the display cable to disconnect it.
  8. Dell Chromebook 3100 2-in-1 Webcam Replacement: stap 8, afbeelding 1 van 2 Dell Chromebook 3100 2-in-1 Webcam Replacement: stap 8, afbeelding 2 van 2
    • Remove the 6 screws (M2.5x5) holding the hinges on both ends.
    • When both brackets are free, separte the screen from the computer screen from the bottom section.
  9. Dell Chromebook 3100 2-in-1 Webcam Replacement: stap 9, afbeelding 1 van 1
    • Use a jimmy to pry between the 2 layers of the now disconnected display.
  10. Dell Chromebook 3100 2-in-1 Webcam Replacement: stap 10, afbeelding 1 van 1
    • Unplug the webcam by gently pulling on the cable shown.
  11. Dell Chromebook 3100 2-in-1 Webcam Replacement: stap 11, afbeelding 1 van 2 Dell Chromebook 3100 2-in-1 Webcam Replacement: stap 11, afbeelding 2 van 2
    • Use a jimmy to pry up the webcam, which is to then be removed.
Conclusie
ot moya
481 Reputatie
3 handleidingen geschreven
IUPUI, Team 3-2, Harley Fall 2023 Lid van IUPUI, Team 3-2, Harley Fall 2023
IUPUI-HARLEY-F23S3G2
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 19
Altijd: 113
