Ga door naar hoofdinhoud
Dell Chromebook 3100 2-in-1 Touchpad Replacement
Wat je nodig hebt
  1. Dell Chromebook 3100 2-in-1 Touchpad Replacement, Touchpad: stap 1, afbeelding 1 van 1
    • To start replacing the touch-pad, unscrew the 9 Phillips head screws holding down the rear cover (It is recommended to use a PH1 bit for the screwdriver).
  2. Dell Chromebook 3100 2-in-1 Touchpad Replacement: stap 2, afbeelding 1 van 1
    • Once all 9 screws are removed, wedge an iFixit Opening Tool in the gap between the rear cover and the rest of the laptop.
    • Once in, gently run the tool around the perimeter of the rear cover. You will hear popping sounds as the plastic tabs detach.
    • After enough tabs have been detached, simply pull off the rear cover.
  3. Dell Chromebook 3100 2-in-1 Touchpad Replacement: stap 3, afbeelding 1 van 1
    • Now that the rear cover is off, the first thing that must be done is to locate and unplug the battery cable from the motherboard.
    • This cable can simply be grabbed and gently pulled out.
  4. Dell Chromebook 3100 2-in-1 Touchpad Replacement: stap 4, afbeelding 1 van 2 Dell Chromebook 3100 2-in-1 Touchpad Replacement: stap 4, afbeelding 2 van 2
    • Using the same PH1 bit for your screw driver, remove the 3 Phillips head screws holding down the battery.
    • Next, lift the battery and remove it from the laptop.
  5. Dell Chromebook 3100 2-in-1 Touchpad Replacement: stap 5, afbeelding 1 van 1
    • Once again, use the PH1 bit for your screwdriver to unscrew the 6 Phillips head screws holding down the touch-pad.
  6. Dell Chromebook 3100 2-in-1 Touchpad Replacement: stap 6, afbeelding 1 van 1
    • With all the screws removed, lift out the metal bracket holding down the touch-pad.
  7. Dell Chromebook 3100 2-in-1 Touchpad Replacement: stap 7, afbeelding 1 van 1
    • Next is to unplug the ribbon cable connecting to the touch-pad.
    • This can be done by flipping the black tab up and gently tugging on the blue handle to remove it.
    • The ribbon cable is very fragile! Be very careful when unplugging it!
  8. Dell Chromebook 3100 2-in-1 Touchpad Replacement: stap 8, afbeelding 1 van 2 Dell Chromebook 3100 2-in-1 Touchpad Replacement: stap 8, afbeelding 2 van 2
    • With the cable unplugged and the metal bracket removed, grab the touch-pad along its edges and lift it off of the laptop.
Conclusie
ot moya
481 Reputatie
3 handleidingen geschreven
IUPUI, Team 3-2, Harley Fall 2023 Lid van IUPUI, Team 3-2, Harley Fall 2023
IUPUI-HARLEY-F23S3G2
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 25
Altijd: 119
