Inleiding
Follow this guide to remove and replace the motherboard in the Dell Chromebook 3100 2-in-1 laptop.
For your safety, discharge your battery below 25% before disassembling it. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
Wat je nodig hebt
Using a Phillips #1 screwdriver, remove all nine of the 5 mm screws from the back cover.
Remove adhesive tape that secures the speaker cable.
Disconnect the speaker cable from the connector on the system board.
6 andere personen hebben deze handleiding voltooid.
