Ga door naar hoofdinhoud
Dell Chromebook 13-7310 Network Card Replacement
Wat je nodig hebt
  1. Dell Chromebook 13-7310 Network Card Replacement, Back Cover: stap 1, afbeelding 1 van 2 Dell Chromebook 13-7310 Network Card Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 Network Card Replacement: stap 2, afbeelding 1 van 1
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 Network Card Replacement, Battery: stap 3, afbeelding 1 van 1
    • Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
  4. Dell Chromebook 13-7310 Network Card Replacement: stap 4, afbeelding 1 van 1
    • Remove the four 2mm screws on the sides of the battery.
  5. Dell Chromebook 13-7310 Network Card Replacement: stap 5, afbeelding 1 van 1
    • To remove the battery, lift up on one side to get your fingers underneath and lift away.
  6. Dell Chromebook 13-7310 Network Card Replacement, Network Card: stap 6, afbeelding 1 van 2 Dell Chromebook 13-7310 Network Card Replacement, Network Card: stap 6, afbeelding 2 van 2
    • Use #1 Phillips screwdriver to remove the 1mm screw in the network card.
  7. Dell Chromebook 13-7310 Network Card Replacement: stap 7, afbeelding 1 van 1
    • Disconnect the network card from motherboard socket.
  8. Dell Chromebook 13-7310 Network Card Replacement: stap 8, afbeelding 1 van 1
    • Disconnect 2 cable connectors from network card.
    • If the cables are stuck, continue to gently wiggle them until they disconnect.
Conclusie
Brett Raymond
469 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team S5-G1, Gulbrandsen Fall 2018 Lid van UMass Dartmouth, Team S5-G1, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G1
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 526
