Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Use a plastic opening tool to gently remove the back panel.
The battery must be removed to access the mouse pad. To remove the battery, undo the two, 2mm screws located on each side.
Once all four screws are removed, unplug the battery connection cable by hand to disconnect the battery from the motherboard.
To remove the battery, lift up on one side to get you fingers underneath and lift away.
Remove the six 2mm screws located around the maouse pad cover.
Using either fingernails or tweezers, lift the black cover on the ribbon cable and pull the cable loose from he motherboard.
Once the ribbon cable is disconnected lift up on the back cove to remove it and expose the mouse pad.
Now that the mouse pad is exposed, lift the assembly to remove the mouse pad.
