Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Use a plastic opening tool to gently remove the back panel.
Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
Remove the four 2mm screws on the sides of the battery.
To remove the battery, lift up on one side to get your fingers underneath and lift away.
Use #1 Phillips screwdriver to remove the 1mm screw in the network card.
Disconnect the network card from motherboard socket.
Remove the eight 2mm screws securing the motherboard in place.
Release cable for the LED charging indicator by pulling up on connector.
Pull up on connector tab to release IO board cable.
Pull up on connector tab to release touchpad cable.
Één opmerking
Is it possible to swap the non-touch matte display and the glossy touchscreen on two Dell Chromebook 13 7310?
