Inleiding
A damaged motherboard is a serious issue and can be a hassle to fix, but it doesn't have to be! By following the quick and easy motherboard replacement guide you can have your Chromebook working again in no time!
Wat je nodig hebt
Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
Use #1 Phillips screwdriver to remove the 1mm screw in the network card.
Één opmerking
Is it possible to swap the non-touch matte display and the glossy touchscreen on two Dell Chromebook 13 7310?
