Ga door naar hoofdinhoud
Dell Chromebook 13-7310 Keyboard Replacement
Wat je nodig hebt
  1. Dell Chromebook 13-7310 Keyboard Replacement, Back Cover: stap 1, afbeelding 1 van 2 Dell Chromebook 13-7310 Keyboard Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 Keyboard Replacement, Battery: stap 3, afbeelding 1 van 1
    • Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
  4. Dell Chromebook 13-7310 Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Remove the four 2mm screws on the sides of the battery.
  5. Dell Chromebook 13-7310 Keyboard Replacement: stap 5, afbeelding 1 van 1
    • To remove the battery, lift up on one side to get your fingers underneath and lift away.
  6. Dell Chromebook 13-7310 Keyboard Replacement, Motherboard: stap 6, afbeelding 1 van 1
    • Gently pull to unplug fan connector.
  7. Dell Chromebook 13-7310 Keyboard Replacement: stap 7, afbeelding 1 van 2 Dell Chromebook 13-7310 Keyboard Replacement: stap 7, afbeelding 2 van 2
    • Remove 4 screws securing heat sink.
  8. Dell Chromebook 13-7310 Keyboard Replacement: stap 8, afbeelding 1 van 1
    • Lift away heat sink.
  9. Dell Chromebook 13-7310 Keyboard Replacement: stap 9, afbeelding 1 van 1
    • Remove the eight 2mm screws securing the motherboard in place.
  10. Dell Chromebook 13-7310 Keyboard Replacement: stap 10, afbeelding 1 van 1
    • Release cable for the LED charging indicator by pulling up on connector.
  11. Dell Chromebook 13-7310 Keyboard Replacement: stap 11, afbeelding 1 van 1
    • Gently remove the cable.
  12. Dell Chromebook 13-7310 Keyboard Replacement: stap 12, afbeelding 1 van 1
    • Pull up on connector tab to release IO board cable.
  13. Dell Chromebook 13-7310 Keyboard Replacement: stap 13, afbeelding 1 van 2 Dell Chromebook 13-7310 Keyboard Replacement: stap 13, afbeelding 2 van 2
    • Pull up on connector tab to release touchpad cable.
  14. Dell Chromebook 13-7310 Keyboard Replacement: stap 14, afbeelding 1 van 1
    • Release the keyboard backlight cable.
  15. Dell Chromebook 13-7310 Keyboard Replacement: stap 15, afbeelding 1 van 2 Dell Chromebook 13-7310 Keyboard Replacement: stap 15, afbeelding 2 van 2
    • Release the keyboard cable.
    • If taped to the motherboard, gently peel it off.
  16. Dell Chromebook 13-7310 Keyboard Replacement: stap 16, afbeelding 1 van 1
    • Release eDP cable.
  17. Dell Chromebook 13-7310 Keyboard Replacement: stap 17, afbeelding 1 van 1
    • Release dc-in cable.
  18. Dell Chromebook 13-7310 Keyboard Replacement: stap 18, afbeelding 1 van 1
    • Gently lift up the motherboard to remove it.
  19. Dell Chromebook 13-7310 Keyboard Replacement, Cooling Fan: stap 19, afbeelding 1 van 2 Dell Chromebook 13-7310 Keyboard Replacement, Cooling Fan: stap 19, afbeelding 2 van 2
    • Using the #1 Philips screwdriver, remove the two, 2mm screws securing the fan assembly.
  20. Dell Chromebook 13-7310 Keyboard Replacement: stap 20, afbeelding 1 van 2 Dell Chromebook 13-7310 Keyboard Replacement: stap 20, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Using your fingernails, pull the cooling fan cables loose from the motherboard.
    • We have the tweezers pictured to allow for a clear view of components. DO NOT use the tweezers to remove the cables, they could be damaged in the process.
    • Finally, lift the fan assembly away from the computer.
  21. Dell Chromebook 13-7310 Keyboard Replacement, IO Board: stap 21, afbeelding 1 van 1
    • Remove the single 2mm screw securing the IO board to the laptop.
  22. Dell Chromebook 13-7310 Keyboard Replacement: stap 22, afbeelding 1 van 1
    • Pull up on the connector to release the IO board cable from the motherboard.
    • It may be easier to pull from the blue tab.
  23. Dell Chromebook 13-7310 Keyboard Replacement: stap 23, afbeelding 1 van 1
    • Remove the IO board.
  24. Dell Chromebook 13-7310 Keyboard Replacement, Keyboard: stap 24, afbeelding 1 van 1
    • Remove all screws.
    • All screws for the keyboard will have a "K" next to them.
  25. Dell Chromebook 13-7310 Keyboard Replacement: stap 25, afbeelding 1 van 1
    • Gently lift up the keyboard and remove.
    • This step does not require much force. If you have to use a lot of force to lift the keyboard, check to make sure you didn't miss a screw.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Damon
181 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S5-G1, Gulbrandsen Fall 2018 Lid van UMass Dartmouth, Team S5-G1, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G1
3 Leden
5 handleidingen geschreven
Één opmerking
I’ve never pulled apart a computer before, and this guide was perfect! thanks
Owen Thomas - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 743
