Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
Computer batteries can sometimes become weaker over time, losing charge and making it difficult to properly use your device. If your battery is not functioning correctly anymore, then follow this guide to remove/replace the battery in a Dell Chromebook 13-7310.
Wat je nodig hebt
Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
Congratulations! You have successfully removed the battery of your Dell Chromebook 13-7310. To reassemble your device, follow these instructions in reverse order.
