Ga door naar hoofdinhoud
Dell Chromebook 11 CB1C13 Fan Replacement
Wat je nodig hebt
  1. Dell Chromebook 11 CB1C13 Fan Replacement, Back Panel: stap 1, afbeelding 1 van 3 Dell Chromebook 11 CB1C13 Fan Replacement, Back Panel: stap 1, afbeelding 2 van 3 Dell Chromebook 11 CB1C13 Fan Replacement, Back Panel: stap 1, afbeelding 3 van 3
    • Make sure that device is fully powered down before attempting to open the back case.
    • Remove all seven 8 mm Philips #0 screws from the back case with a Philips #0 screwdriver.
    • Once all seven screws are removed, you can pry the case off using your fingers or a plastic opening tool.
  2. Dell Chromebook 11 CB1C13 Fan Replacement, Fan: stap 2, afbeelding 1 van 3 Dell Chromebook 11 CB1C13 Fan Replacement, Fan: stap 2, afbeelding 2 van 3 Dell Chromebook 11 CB1C13 Fan Replacement, Fan: stap 2, afbeelding 3 van 3
    • Locate the two wires that connect the fan to the device. One black, and one white.
    • Move these wires off of the fan by gently pulling on them.
    • Locate the two 8mm Philips #0 screws that connect the fan to the device.
    • Remove these screws using a Philips #0 screwdriver.
  3. Dell Chromebook 11 CB1C13 Fan Replacement: stap 3, afbeelding 1 van 3 Dell Chromebook 11 CB1C13 Fan Replacement: stap 3, afbeelding 2 van 3 Dell Chromebook 11 CB1C13 Fan Replacement: stap 3, afbeelding 3 van 3
    • The fan is connected by a 5 pin port. Remove this by gently prying out the fan's port using your fingers or a plastic prying tool.
    • The pin port can be very delicate. Any major bending or twisting can cause permanent damage to the port, and may leave it unable to work.
Conclusie
Bryan Allen
272 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S3-G6, Bailey Fall 2017 Lid van UMass Dartmouth, Team S3-G6, Bailey Fall 2017
UMASSD-BAILEY-F17S3G6
3 Leden
7 handleidingen geschreven
Één opmerking
Ram?
Can i change the ram?
flip - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 17
Altijd: 1,037
