Ga door naar hoofdinhoud
Dell Chromebook 11 CB1C13 Battery Replacement
Wat je nodig hebt
  1. Dell Chromebook 11 CB1C13 Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Dell Chromebook 11 CB1C13 Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Dell Chromebook 11 CB1C13 Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Make sure that device is fully powered down before attempting to open the back case.
    • Remove all seven 8mm Philips #0 screws from the back case with a Philips #0 screwdriver.
    • Once all seven screws are removed, you can pry the case off using your fingers or a plastic opening tool.
  2. Dell Chromebook 11 CB1C13 Battery Replacement: stap 2, afbeelding 1 van 2 Dell Chromebook 11 CB1C13 Battery Replacement: stap 2, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to unscrew the four 8 mm screws that secure the battery.
  3. Dell Chromebook 11 CB1C13 Battery Replacement: stap 3, afbeelding 1 van 2 Dell Chromebook 11 CB1C13 Battery Replacement: stap 3, afbeelding 2 van 2
    • Use a plastic spudger to push the bundled cable connector free in the same direction as the individual wires are running.
    • You can use your fingers to help pull the cable free. Pull evenly on the full width of the cable so that no individual wires are overly strained.
    • Proceed to gently remove the battery from the back panel.
Conclusie
To replace your Dell Chromebook 11 battery, follow these instructions in order.
Jerry Geffrard
334 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team S3-G6, Bailey Fall 2017 Lid van UMass Dartmouth, Team S3-G6, Bailey Fall 2017
UMASSD-BAILEY-F17S3G6
3 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 1,403
