Inleiding
This guide will display how to replace the battery. A recall was issued on the batteries that came with the Dell Chromebook 11, so it is very important to know how to replace them. A faulty battery may not only be unable to hold a charge, but could also cause severe damage to the device.
Wat je nodig hebt
Remove all seven 8mm Philips #0 screws from the back case with a Philips #0 screwdriver.
Once all seven screws are removed, you can pry the case off using your fingers or a plastic opening tool.
To replace your Dell Chromebook 11 battery, follow these instructions in order.
