Inleiding
In this guide, we will show you how to remove and replace the Hard Drive.
Wat je nodig hebt
Lift the connector latch that secures the hard-drive cable to the connector on the system board, and then disconnect the hard-drive cable from the connector on the system board.
Loosen the four captive screws that secure the hard-drive assembly to the computer base.
Using the pull-tab, lift the hard-drive assembly out of the computer base.
Remove the four screws that secure the primary hard drive (HDD 0) and lift the hard drive out of the hard -drive bracket.
Remove the four screws that secure the secondary hard drive (HDD 1) and slide the hard drive out of the hard-drive bracket.
Place the primary hard drive (HDD0) in the hard-drive bracket.
If applicable, slide the secondary hard drive into the hard-drive bracket.
Replace the four screws that secure the primary hard drive (HDD 0).
If applicable, replace the four screws that secure the secondary hard drive (HDD 1) to the hard-drive bracket.
Connect the interposer to the hard drives.
Place the hard-drive assembly in the computer base.
Tighten the four captive screws that secure the hard-drive assembly to the computer base.
Connect the hard-drive cable to the connector on the system board and press down on the connector latch to secure the cable.
