Inleiding
In this guide, we will be showing you how to remove and replace the Memory Modules.
Wat je nodig hebt
Loosen the captive screw that secures the memory-module door to the computer base.
Slide the memory-module door to release the tabs and lift the memory- module door out of the computer base.
Use your fingertips to carefully spread apart the spring-locks on the memory module connector until the module pops up.
Align the notch on the NEW memory module with the tab on the memory module connector.
Insert the module into the memory module connector at a 45-degree angle, and press the module down until it clicks into place. If you do not hear the click, remove the module and reinstall it.
