Ga door naar hoofdinhoud
Dell Alienware M11x R3 Wi-Fi Card Replacement
Wat je nodig hebt
  1. Dell Alienware M11x R3 Wi-Fi Card Replacement, Lower Case: stap 1, afbeelding 1 van 3 Dell Alienware M11x R3 Wi-Fi Card Replacement, Lower Case: stap 1, afbeelding 2 van 3 Dell Alienware M11x R3 Wi-Fi Card Replacement, Lower Case: stap 1, afbeelding 3 van 3
    • Loosen the eight retaining screws on the base of the computer with a small Phillips screwdriver.
    • The screws have retaining washers to hold them in place, so you don't have to remove them from the base plate.
    • Remove the bottom cover from the laptop.
  2. Dell Alienware M11x R3 Wi-Fi Card Replacement, Wi-Fi Card: stap 2, afbeelding 1 van 2 Dell Alienware M11x R3 Wi-Fi Card Replacement, Wi-Fi Card: stap 2, afbeelding 2 van 2
    • Your Wi-Fi card will have two coaxial cable wires connected to it.
    • Gently pull up the wires to disconnect them from the Wi-Fi card.
    • Be careful when you pull the wires. Pulling them hard or yanking them hard might cause damage to the wire or the Wi-Fi card.
  3. Dell Alienware M11x R3 Wi-Fi Card Replacement: stap 3, afbeelding 1 van 1
    • Once the wires are removed, use an appropriate screwdriver to remove the screws holding down the Wi-Fi card.
  4. Dell Alienware M11x R3 Wi-Fi Card Replacement: stap 4, afbeelding 1 van 2 Dell Alienware M11x R3 Wi-Fi Card Replacement: stap 4, afbeelding 2 van 2
    • When the Wi-Fi card pop ups, slide it out of the socket.
    • Any mishandling of the Wi-Fi card will cause serious damage to it, so please be careful with it.
Conclusie
Richard Maurice
534 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team S3-G7, Botvin Spring 2017 Lid van UMass Dartmouth, Team S3-G7, Botvin Spring 2017
UMASSD-BOTVIN-S17S3G7
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 695
