Ga door naar hoofdinhoud
Dell Alienware M11x R3 2.5" Hard Drive Replacement
Wat je nodig hebt
  1. Dell Alienware M11x R3  2.5" Hard Drive Replacement, Lower Case: stap 1, afbeelding 1 van 3 Dell Alienware M11x R3  2.5" Hard Drive Replacement, Lower Case: stap 1, afbeelding 2 van 3 Dell Alienware M11x R3  2.5" Hard Drive Replacement, Lower Case: stap 1, afbeelding 3 van 3
    • Loosen the eight retaining screws on the base of the computer with a small Phillips screwdriver.
    • The screws have retaining washers to hold them in place, so you don't have to remove them from the base plate.
    • Remove the bottom cover from the laptop.
  2. Dell Alienware M11x R3  2.5" Hard Drive Replacement, Hard Drive: stap 2, afbeelding 1 van 1
    • Remove the three screws attaching the hard drive tray to the laptop.
  3. Dell Alienware M11x R3  2.5" Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • Grasp the plastic tab provided, and gently pull up. This will unplug the drive from the laptop.
  4. Dell Alienware M11x R3  2.5" Hard Drive Replacement: stap 4, afbeelding 1 van 2 Dell Alienware M11x R3  2.5" Hard Drive Replacement: stap 4, afbeelding 2 van 2
    • On both sides of the cage, there are two screws you have to unscrew to be able to remove the SSD.
  5. Dell Alienware M11x R3  2.5" Hard Drive Replacement: stap 5, afbeelding 1 van 2 Dell Alienware M11x R3  2.5" Hard Drive Replacement: stap 5, afbeelding 2 van 2
    • Finally, remove the L connector for the hard drive. You will need to put this on your new hard drive.
    • Make sure that the SSD you bought to replace this one has the same connections. I.e. able to connect to a SATA cord.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Richard Maurice
534 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team S3-G7, Botvin Spring 2017 Lid van UMass Dartmouth, Team S3-G7, Botvin Spring 2017
UMASSD-BOTVIN-S17S3G7
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 21
Altijd: 1,577
