Ga door naar hoofdinhoud
Dell Alienware 15 R3 Wi-Fi Card Replacement
Wat je nodig hebt
  1. Dell Alienware 15 R3 Wi-Fi Card Replacement, Back Case: stap 1, afbeelding 1 van 3 Dell Alienware 15 R3 Wi-Fi Card Replacement, Back Case: stap 1, afbeelding 2 van 3 Dell Alienware 15 R3 Wi-Fi Card Replacement, Back Case: stap 1, afbeelding 3 van 3
    • Before you begin, turn off the laptop and unplug the charger.
    • Flip the laptop over so that the backside is facing up.
    • Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
    • Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
  2. Dell Alienware 15 R3 Wi-Fi Card Replacement: stap 2, afbeelding 1 van 1
    • Use the opening tool to pry the back case from the computer.
    • Use the opening tool and work your way around the perimeter of the back case to gently release the clips.
    • Start from the black vent for an easier removal.
    • Lift the back case off of the laptop.
  3. Dell Alienware 15 R3 Wi-Fi Card Replacement, Cover Assembly: stap 3, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove two screws from the side of the laptop.
  4. Dell Alienware 15 R3 Wi-Fi Card Replacement: stap 4, afbeelding 1 van 2 Dell Alienware 15 R3 Wi-Fi Card Replacement: stap 4, afbeelding 2 van 2
    • Use an opening tool to release the four tabs from the hinge cover and gently pry it off.
  5. Dell Alienware 15 R3 Wi-Fi Card Replacement: stap 5, afbeelding 1 van 3 Dell Alienware 15 R3 Wi-Fi Card Replacement: stap 5, afbeelding 2 van 3 Dell Alienware 15 R3 Wi-Fi Card Replacement: stap 5, afbeelding 3 van 3
    • Use a Phillips #00 screwdriver to remove nine screws from the chassis.
    • Use a spudger or opening tool to remove the chassis and reveal the battery, fan, motherboard, and other components.
  6. Dell Alienware 15 R3 Wi-Fi Card Replacement, Wi-Fi Card: stap 6, afbeelding 1 van 3 Dell Alienware 15 R3 Wi-Fi Card Replacement, Wi-Fi Card: stap 6, afbeelding 2 van 3 Dell Alienware 15 R3 Wi-Fi Card Replacement, Wi-Fi Card: stap 6, afbeelding 3 van 3
    • Open the flap to reveal the Wi-Fi card.
    • Use the Phillips #00 screwdriver to remove the screw securing the Wi-Fi card.
    • Use a spudger to detach the coaxial cables from the Wi-Fi card.
    • Be careful when detaching these cable connectors from the Wi-Fi card. The base of the connectors are prone to break off.
Conclusie
Jake Nelson
581 Reputatie
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 30
Altijd: 338
