Inleiding
This is a guide that will help you when it comes to replacing the RAM on a Dell Alienware 15 R3 laptop.
Before beginning this repair, turn off the laptop and unplug it from the charging cord.
Wat je nodig hebt
Flip the laptop over so that the backside is facing up.
Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
To remove the old RAM sticks, push the metal arms out to the side, using an opening tool or your fingers.
Slide the RAM stick out at a 45 degree angle.
