Ga door naar hoofdinhoud
Dell Alienware 15 R3 Cover Assembly Replacement
Wat je nodig hebt
  1. Dell Alienware 15 R3 Cover Assembly Replacement, Back Case: stap 1, afbeelding 1 van 3 Dell Alienware 15 R3 Cover Assembly Replacement, Back Case: stap 1, afbeelding 2 van 3 Dell Alienware 15 R3 Cover Assembly Replacement, Back Case: stap 1, afbeelding 3 van 3
    • Before you begin, turn off the laptop and unplug the charger.
    • Flip the laptop over so that the backside is facing up.
    • Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
    • Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
  2. Dell Alienware 15 R3 Cover Assembly Replacement: stap 2, afbeelding 1 van 1
    • Use the opening tool to pry the back case from the computer.
    • Use the opening tool and work your way around the perimeter of the back case to gently release the clips.
    • Start from the black vent for an easier removal.
    • Lift the back case off of the laptop.
  3. Dell Alienware 15 R3 Cover Assembly Replacement, Cover Assembly: stap 3, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove two screws from the side of the laptop.
  4. Dell Alienware 15 R3 Cover Assembly Replacement: stap 4, afbeelding 1 van 2 Dell Alienware 15 R3 Cover Assembly Replacement: stap 4, afbeelding 2 van 2
    • Use an opening tool to release the four tabs from the hinge cover and gently pry it off.
  5. Dell Alienware 15 R3 Cover Assembly Replacement: stap 5, afbeelding 1 van 3 Dell Alienware 15 R3 Cover Assembly Replacement: stap 5, afbeelding 2 van 3 Dell Alienware 15 R3 Cover Assembly Replacement: stap 5, afbeelding 3 van 3
    • Use a Phillips #00 screwdriver to remove nine screws from the chassis.
    • Use a spudger or opening tool to remove the chassis and reveal the battery, fan, motherboard, and other components.
Conclusie
Jake Nelson
581 Reputatie
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 28
Altijd: 424
