Ga door naar hoofdinhoud
Dell Alienware 13 Speakers Replacement
Wat je nodig hebt
  1. Dell Alienware 13 Speakers Replacement, Base Panel: stap 1, afbeelding 1 van 1
    • Working on an electrical device while plugged in can cause injury due to electrical shock. Ensure that all external power is disconnected from the device.
    • Close the device and turn the device over.
  2. Dell Alienware 13 Speakers Replacement: stap 2, afbeelding 1 van 1
    • Remove (2) 5 mm Phillips head screws attaching the small access panel to the base using a Phillips # 1 screwdriver.
    • The (2) screws are attached to the base panel with retaining clips and won't completely detach from the panel.
  3. Dell Alienware 13 Speakers Replacement: stap 3, afbeelding 1 van 3 Dell Alienware 13 Speakers Replacement: stap 3, afbeelding 2 van 3 Dell Alienware 13 Speakers Replacement: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Heavy-Duty Spudger
    Koop
  4. Dell Alienware 13 Speakers Replacement, Computer Base: stap 4, afbeelding 1 van 2 Dell Alienware 13 Speakers Replacement, Computer Base: stap 4, afbeelding 2 van 2
    • Disconnect the battery cable from the battery cable terminal.
  5. Dell Alienware 13 Speakers Replacement: stap 5, afbeelding 1 van 1
    • Remove (4) 6 mm Phillips head screws from the solid-state metal drive bracket, using a Phillips # 1 screwdriver.
  6. Dell Alienware 13 Speakers Replacement: stap 6, afbeelding 1 van 2 Dell Alienware 13 Speakers Replacement: stap 6, afbeelding 2 van 2
    • Grab the pull tab to pivot the solid-state drive bracket upwards. Remove the bracket from the computer base.
  7. Dell Alienware 13 Speakers Replacement: stap 7, afbeelding 1 van 2 Dell Alienware 13 Speakers Replacement: stap 7, afbeelding 2 van 2
    • Using the pull tab, disconnect the black solid-state drive cable from the system board.
  8. Dell Alienware 13 Speakers Replacement: stap 8, afbeelding 1 van 1
    • Remove (2) 3 mm Phillips head screws, using a Phillips # 0 screwdriver, that connect the solid-state drive assembly to the computer base.
  9. Dell Alienware 13 Speakers Replacement: stap 9, afbeelding 1 van 2 Dell Alienware 13 Speakers Replacement: stap 9, afbeelding 2 van 2
    • Lift up on the solid-state drive assembly to remove it from the computer base.
  10. Dell Alienware 13 Speakers Replacement: stap 10, afbeelding 1 van 2 Dell Alienware 13 Speakers Replacement: stap 10, afbeelding 2 van 2
    • Locate two cables labeled, "KB Backlight" (orange) and "KB Membrane" (black). Lift up on the latches to disconnect the cables from the system board.
    • The latches that connect the cables to the system board are very delicate. Handle with care to avoid damaging them.
  11. Dell Alienware 13 Speakers Replacement: stap 11, afbeelding 1 van 3 Dell Alienware 13 Speakers Replacement: stap 11, afbeelding 2 van 3 Dell Alienware 13 Speakers Replacement: stap 11, afbeelding 3 van 3
    • Remove (8) 9 mm Phillips head screws using a Phillips # 1 screwdriver, that secures the palm-rest assembly to the computer base.
    • Remove (4) 8 mm Phillips head screws using a Phillips # 1 screwdriver.
    • Remove (2) 7 mm Phillips head screws using a Phillips # 1 screwdriver.
  12. Dell Alienware 13 Speakers Replacement: stap 12, afbeelding 1 van 2 Dell Alienware 13 Speakers Replacement: stap 12, afbeelding 2 van 2
    • Lift the computer base slightly towards you and push the release tabs on the palm-rest assembly until it pops out using a spudger.
  13. Dell Alienware 13 Speakers Replacement: stap 13, afbeelding 1 van 3 Dell Alienware 13 Speakers Replacement: stap 13, afbeelding 2 van 3 Dell Alienware 13 Speakers Replacement: stap 13, afbeelding 3 van 3
    • Turn the computer over and open the display as far as possible.
    • Using a plastic spudger, pry up along the edges of the palm-rest assembly.
    • Gently lift the palm-rest assembly.
  14. Dell Alienware 13 Speakers Replacement: stap 14, afbeelding 1 van 3 Dell Alienware 13 Speakers Replacement: stap 14, afbeelding 2 van 3 Dell Alienware 13 Speakers Replacement: stap 14, afbeelding 3 van 3
    • Lift the connector latch and disconnect the power-button board cable from the system board. Identified as a cable with a blue tab.
    • Lift the palm-rest assembly off the computer base.
  15. Dell Alienware 13 Speakers Replacement: stap 15, afbeelding 1 van 3 Dell Alienware 13 Speakers Replacement: stap 15, afbeelding 2 van 3 Dell Alienware 13 Speakers Replacement: stap 15, afbeelding 3 van 3
    • Open the display as far as possible.
    • Remove (2) 3 mm Phillips head screws, using a Phillips head #0 screwdriver, that secure the hinge caps to the display hinges.
    • Slide and lift the hinge caps off the display hinges.
  16. Dell Alienware 13 Speakers Replacement: stap 16, afbeelding 1 van 2 Dell Alienware 13 Speakers Replacement: stap 16, afbeelding 2 van 2
    • Close the display and turn the computer over.
    • Remove (1) 2 mm Phillips head screw, using a Phillips head # 0 screwdriver, that secures the wireless-card bracket to the wireless card.
  17. Dell Alienware 13 Speakers Replacement: stap 17, afbeelding 1 van 2 Dell Alienware 13 Speakers Replacement: stap 17, afbeelding 2 van 2
    Heavy-Duty Spudger
    Koop
    • Disconnect the antenna cables from the wireless card using a heavy duty spudger. The wires can be removed by applying a force directed upward, away from the device.
  18. Dell Alienware 13 Speakers Replacement: stap 18, afbeelding 1 van 3 Dell Alienware 13 Speakers Replacement: stap 18, afbeelding 2 van 3 Dell Alienware 13 Speakers Replacement: stap 18, afbeelding 3 van 3
    • Turn the computer over and open the display.
    • Peel off the adhesive tapes that secure the antenna cables to the system board.
    • Make note of how the cables are routed before removing any cables from their routing guide.
  19. Dell Alienware 13 Speakers Replacement: stap 19, afbeelding 1 van 3 Dell Alienware 13 Speakers Replacement: stap 19, afbeelding 2 van 3 Dell Alienware 13 Speakers Replacement: stap 19, afbeelding 3 van 3
    • Lift the connector latch and disconnect the display cable from the system board.
    • Disconnect the logo-board cable from the system board.
    • Remove the antenna cables, display cable, and logo-board cable from the routing guides on the display hinges.
  20. Dell Alienware 13 Speakers Replacement: stap 20, afbeelding 1 van 3 Dell Alienware 13 Speakers Replacement: stap 20, afbeelding 2 van 3 Dell Alienware 13 Speakers Replacement: stap 20, afbeelding 3 van 3
    • Remove (4) 8 mm Phillips head screws, using a Phillips # 1 screwdriver, that secure the display assembly to the computer base.
    • Lift the display assembly off the computer base.
  21. Dell Alienware 13 Speakers Replacement: stap 21, afbeelding 1 van 2 Dell Alienware 13 Speakers Replacement: stap 21, afbeelding 2 van 2
    • Remove the (2) 6 mm Phillips head screws securing the power adapter port bracket with a #1 Phillips screwdriver.
    • Lift and remove the power adapter port bracket.
  22. Dell Alienware 13 Speakers Replacement: stap 22, afbeelding 1 van 1
    • Lift up and remove the power adapter port from the computer base.
  23. Dell Alienware 13 Speakers Replacement: stap 23, afbeelding 1 van 2 Dell Alienware 13 Speakers Replacement: stap 23, afbeelding 2 van 2
    • Disconnect the speaker cable connector from the service board.
  24. Dell Alienware 13 Speakers Replacement: stap 24, afbeelding 1 van 3 Dell Alienware 13 Speakers Replacement: stap 24, afbeelding 2 van 3 Dell Alienware 13 Speakers Replacement: stap 24, afbeelding 3 van 3
    • Remove (3) 6 mm Phillips head screws securing the service board with a #1 Phillips screwdriver.
    • Lift up on the service board assembly using a heavy duty spudger and slide the board towards the battery to remove from the base.
  25. Dell Alienware 13 Speakers Replacement, Battery: stap 25, afbeelding 1 van 1
    • Remove the speaker cable from the cable clip on the battery.
  26. Dell Alienware 13 Speakers Replacement: stap 26, afbeelding 1 van 3 Dell Alienware 13 Speakers Replacement: stap 26, afbeelding 2 van 3 Dell Alienware 13 Speakers Replacement: stap 26, afbeelding 3 van 3
    • Remove (2) 6 mm Phillips head screws securing the battery to the computer base with a #1 Phillips screwdriver.
    • Lift up and remove the battery from the computer base.
    • Lithium can be explosive, especially when wet. Be careful when handling and disposing of lithium-ion batteries.
  27. Dell Alienware 13 Speakers Replacement, Speakers: stap 27, afbeelding 1 van 3 Dell Alienware 13 Speakers Replacement, Speakers: stap 27, afbeelding 2 van 3 Dell Alienware 13 Speakers Replacement, Speakers: stap 27, afbeelding 3 van 3
    • After removing the battery, lift up on the speakers and wires to fully removed from the base panel.
Conclusie
Adam Russell
898 Reputatie
6 handleidingen geschreven
USF Tampa, Team 14-2, Eyestone Fall 2016 Lid van USF Tampa, Team 14-2, Eyestone Fall 2016
USFT-EYESTONE-F16S14G2
3 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 15
Altijd: 476
