Inleiding
In this guide, we will show you how to remove and replace the display back-cover.
Wat je nodig hebt
Loosen the captive screws that secure the base panel to the computer base.
Using a plastic scribe, gently release the tabs that secure the base panel to the computer base.
Disconnect the battery cable from the battery-cable connector.
Turn the computer over.
Press and hold the power button for 5 seconds to ground the system board.
Align the tabs on the base panel with the slots on the computer base and snap the base panel into place.
Tighten the captive screws that secure the base panel to the computer base.
Remove the screws that secure the solid-state drive bracket to the solid-state drive assembly.
Using the pull tab, pivot the solid-state drive bracket and peel off the bracket from the tabs on the computer base.
Using the pull tab, disconnect the solid-state drive cable from the system board.
Remove the screws that secure the solid-state drive assembly to the computer base.
Lift the solid-state drive assembly off the computer base.
Remove the screw that secures the solid-state drive to the solid-state drive assembly.
Slide and lift the solid-state drive off the solid-state drive assembly.
Slide the NEW solid-state drive into the slot on the solid-state drive assembly.
Replace the screw that secures the solid-state drive to the solid-state drive assembly.
Align the screw holes on the solid-state drive assembly with the screw holes on the computer base.
Replace the screws that secure the solid-state drive assembly to the computer base.
Connect the solid-state drive cable to the system board.
Align the screw holes on the solid-state drive bracket with the screw holes on the solid-state drive assembly.
Replace the screws that secure the solid-state drive bracket to the solid-state drive assembly.
Lift the latches and disconnect the keyboard and keyboard-backlight cables from the system board.
Remove the screws that secure the palm-rest assembly to the computer base.
Lift the computer base slightly and push the release tabs on the palm-rest assembly until it pops out.
Turn the computer over and open the display as far as possible.
Using a plastic scribe, pry up along the edges of the palm-rest assembly.
Lift the connector latch and disconnect the power-button board cable from the system board.
Remove the keyboard.
Remove the power-button board.
Remove the status-light board.
Remove the Touchpad.
Replace the touchpad.
Replace the status-light board.
Replace the power-button board.
Replace the keyboard.
Connect the power-button board cable to the system board.
Align the palm-rest assembly on the computer base and snap it into place.
Replace the screws that secure the palm-rest assembly to the computer base.
Connect the keyboard cable and the keyboard-backlight cable to the system board.
Remove the screws that secure the hinge caps to the display hinges.
Remove the screw that secures the wireless-card bracket to the wireless card.
Disconnect the antenna cables from the wireless card.
Remove the antenna cables from the routing guides on the display hinges.
Lift the connector latch and disconnect the display cable from the system board.
Remove the display cable from the routing guides on the display hinges.
Disconnect the logo-board cable from the system board and remove it from the routing guides on the display hinges.
Remove the screws that secure the display assembly to the computer base.
Align the screw holes on the display hinges with the screw holes on the computer base.
Replace the screws that secure the display hinges to the computer base.
Route the logo-board cable through the routing guides on the display hinge and connect the logo-board cable to the system board.
Route the display cable through the routing guides on the display hinge.
Slide the display cable into the connector on the system board and press down the latch to secure the cable.
Route the antenna cables through the routing guides on the display hinges.
Adhere the adhesive tapes that secure the antenna cables to the system board.
Replace the screw that secures the wireless-card bracket to the wireless card.
Align the screw holes on the hinge caps with the screw holes on the display hinges.
Replace the screws that secure the hinge caps to the display hinges.
WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
Using your fingertips, carefully pry up the inside edges of the display bezel.
Lift the connector latches and disconnect the display-board cables from the logo board.
Disconnect the logo-board cable from the logo board.
Slide the display-board cables to their respective connectors on the logo board and press down the latches to secure the cables.
Align the display bezel with the display back-cover and gently snap the display bezel into place.
Remove the screws that secure the display panel to the display back-cover.
Lift the connector latch and disconnect the display cable from the display panel.
Connect the NEW display cable to the display panel and press down on the connector latch to secure the cable.
Align the screw holes on the display panel with the screw holes on the display back-cover.
Replace the screws that secure the display panel to the display back-cover.
Remove the screws that secure the display hinges to the display back-cover.
Align the screw holes on the NEW display hinges with the screw holes on the display back-cover.
Replace the screws that secure the display hinges to the display back-cover.
Using a plastic scribe, pry the camera module off the display back-cover.
Using the alignment posts place the NEW camera module on the display back-cover and snap it into place.
Peel the display-board cable to access the camera cable.
Note the display cable routing and peel the camera cable off the display back-cover.
Adhere the display-board cable and the camera cable to the NEW display back-cover.
