Inleiding
Use this guide to replace the circuit board in a Dell Adamo 13 laptop computer.
Rarely will you ever need to replace a circuit board but if you do it is most likely because it has burn marks, scratches, damaged wires or cracks on it that may be disrupting the function of your laptop.
There are no special skills or tools needed to complete this guide.
Before beginning, be sure to completely power off your device.
Wat je nodig hebt
Using the Phillips #0 screwdriver, remove six 2 mm screws securing the fan and motherboard to the device.
