Ga door naar hoofdinhoud
Dell AC511 Hanger Replacement
Wat je nodig hebt
  1. Dell AC511 Hanger Replacement, Front Panel: stap 1, afbeelding 1 van 3 Dell AC511 Hanger Replacement, Front Panel: stap 1, afbeelding 2 van 3 Dell AC511 Hanger Replacement, Front Panel: stap 1, afbeelding 3 van 3
    • Use a Jimmy to peel off the screen stuck to the front of the speaker.
    • Start from any corner and use the Jimmy to get under the screen. Once one side lifts up, you can use your fingers to peel the rest off.
    • Be careful to avoid damage to the rest of the speaker and especially to yourself.
    • Don't worry if it tears; use the Jimmy again to peel off the rest.
  2. Dell AC511 Hanger Replacement: stap 2, afbeelding 1 van 2 Dell AC511 Hanger Replacement: stap 2, afbeelding 2 van 2
    • Remove ten 6 mm screws using a Phillips #1 screwdriver.
  3. Dell AC511 Hanger Replacement: stap 3, afbeelding 1 van 2 Dell AC511 Hanger Replacement: stap 3, afbeelding 2 van 2
    • Lift the front panel off of the rest of the device.
    • The speakers will still be attached to the front panel. Being too rough could damage them.
    • Remove the 4 mm screws from the speakers using a JIS #1 screwdriver.
    • Remove the front panel from the device.
  4. Dell AC511 Hanger Replacement, Hanger: stap 4, afbeelding 1 van 2 Dell AC511 Hanger Replacement, Hanger: stap 4, afbeelding 2 van 2
    • The speakers do not have to have been removed for this step, though it may make it easier.
    • Remove the screws from the hangers you are looking to replace using a JIS #1 screwdriver.
    • We accidentally removed some of the rubber lining the inside along with the hanger. Use a razor to cut it off before removing the hanger.
Conclusie
William Cook
653 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 4-6, Shaddix Spring 2024 Lid van UMass Dartmouth, Team 4-6, Shaddix Spring 2024
UMASSD-SHADDIX-S24S4G6
4 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 17
Altijd: 218
