Ga door naar hoofdinhoud
Dell 1350cnw Printing Image Output Board Replacement
Wat je nodig hebt
  1. Dell 1350cnw Printing Image Output Board Replacement, Unclip front top band: stap 1, afbeelding 1 van 2 Dell 1350cnw Printing Image Output Board Replacement, Unclip front top band: stap 1, afbeelding 2 van 2
    • Insert prying tool behind each end of the plastic strip. Pry outwards to unclip and pull the ends forwards away from the printer.
    • Note - Unclipping the right-hand end requires opening the toner cover for access.
  2. Dell 1350cnw Printing Image Output Board Replacement, Unclip front top band: stap 2, afbeelding 1 van 2 Dell 1350cnw Printing Image Output Board Replacement, Unclip front top band: stap 2, afbeelding 2 van 2
    • Insert prying tool between the front band and top cover of the printer, and pry forwards to release the clips holding the top edge in place.
  3. Dell 1350cnw Printing Image Output Board Replacement, Remove front top band: stap 3, afbeelding 1 van 1
    • Tilt the top of the front band away from the printer and lift away to remove.
  4. Dell 1350cnw Printing Image Output Board Replacement, Remove left-side top band: stap 4, afbeelding 1 van 3 Dell 1350cnw Printing Image Output Board Replacement, Remove left-side top band: stap 4, afbeelding 2 van 3 Dell 1350cnw Printing Image Output Board Replacement, Remove left-side top band: stap 4, afbeelding 3 van 3
    • Unclip the back end of the plastic trim by prying away from the printer back panel.
    • Pull the trim piece towards the back of the printer.
    • Tilt the top edge away from the printer and lift away to remove.
  5. Dell 1350cnw Printing Image Output Board Replacement, Remove control panel module: stap 5, afbeelding 1 van 3 Dell 1350cnw Printing Image Output Board Replacement, Remove control panel module: stap 5, afbeelding 2 van 3 Dell 1350cnw Printing Image Output Board Replacement, Remove control panel module: stap 5, afbeelding 3 van 3
    • Pry up front edge of the control panel module to unclip.
    • Lift up front edge and pull module forwards slightly to unhook rear edge.
    • Pull out cable connector to unplug the display/ control panel module.
  6. Dell 1350cnw Printing Image Output Board Replacement, Remove front cover: stap 6, afbeelding 1 van 1
    • Remove the front lower flap by carefully bending in the middle and pulling out the locating pins one end at a time.
  7. Dell 1350cnw Printing Image Output Board Replacement, Remove front cover: stap 7, afbeelding 1 van 1
    • Remove both 7mm phillips screws securing the front cover in place.
  8. Dell 1350cnw Printing Image Output Board Replacement, Remove front cover: stap 8, afbeelding 1 van 3 Dell 1350cnw Printing Image Output Board Replacement, Remove front cover: stap 8, afbeelding 2 van 3 Dell 1350cnw Printing Image Output Board Replacement, Remove front cover: stap 8, afbeelding 3 van 3
    • Unclip the three clips along each end of the front cover by prying outwards and forwards with a prying tool as shown.
  9. Dell 1350cnw Printing Image Output Board Replacement, Remove front cover: stap 9, afbeelding 1 van 1
    • Slide out the bottom edge away from the printer and pull the front cover down away from the top edge to remove.
  10. Dell 1350cnw Printing Image Output Board Replacement, Remove top cover: stap 10, afbeelding 1 van 2 Dell 1350cnw Printing Image Output Board Replacement, Remove top cover: stap 10, afbeelding 2 van 2
    • Undo both the 5mm M3 phillips screws holding the top cover brackets to the chassis.
  11. Dell 1350cnw Printing Image Output Board Replacement, Remove top cover: stap 11, afbeelding 1 van 2 Dell 1350cnw Printing Image Output Board Replacement, Remove top cover: stap 11, afbeelding 2 van 2
    • Pull the top cover brackets forwards off the metal frame and lift up to loosen the front edge of the top cover.
  12. Dell 1350cnw Printing Image Output Board Replacement, Remove top cover: stap 12, afbeelding 1 van 1
    • Pry the top cover clip off the locating peg at the back of the printer, and lift up the top cover corner.
  13. Dell 1350cnw Printing Image Output Board Replacement, Remove top cover: stap 13, afbeelding 1 van 1
    • Pry apart the back edge of the top cover and the back cover of the printer to unclip the top cover.
  14. Dell 1350cnw Printing Image Output Board Replacement, Remove top cover: stap 14, afbeelding 1 van 1
    • Lift up the top cover from the control panel corner, pulling towards the back right-hand corner.
    • Note - The top cover should unclip from the back corner with the corner/side piece still attached.
  15. Dell 1350cnw Printing Image Output Board Replacement, Remove side cover: stap 15, afbeelding 1 van 3 Dell 1350cnw Printing Image Output Board Replacement, Remove side cover: stap 15, afbeelding 2 van 3 Dell 1350cnw Printing Image Output Board Replacement, Remove side cover: stap 15, afbeelding 3 van 3
    • Unclip the back edge of the side cover by prying away from the printer back panel.
    • Pull the top of the side panel away from the printer.
    • Lift up the printer from underneath to release the bottom clips, and the side panel drops away from the printer.
  16. Dell 1350cnw Printing Image Output Board Replacement, Unplug WiFi module: stap 16, afbeelding 1 van 1
    • Pull out the WiFi module plug from the USB/Ethernet board to disconnect.
  17. Dell 1350cnw Printing Image Output Board Replacement, Remove WiFi module: stap 17, afbeelding 1 van 2 Dell 1350cnw Printing Image Output Board Replacement, Remove WiFi module: stap 17, afbeelding 2 van 2
    • Unscrew the 7mm phillips screw holding the WiFi module to the printer and remove the WiFi module.
  18. Dell 1350cnw Printing Image Output Board Replacement, Unplug cables: stap 18, afbeelding 1 van 3 Dell 1350cnw Printing Image Output Board Replacement, Unplug cables: stap 18, afbeelding 2 van 3 Dell 1350cnw Printing Image Output Board Replacement, Unplug cables: stap 18, afbeelding 3 van 3
    • Lift up the locking tab to unclip and release the flat flex data cable.
    • Gently pull the flat flex cable out from from the connector.
  19. Dell 1350cnw Printing Image Output Board Replacement, Unplug cables: stap 19, afbeelding 1 van 1
    • Pull the smaller flat flex cable out from its connector to remove, and repeat for the remaining two connectors.
  20. Dell 1350cnw Printing Image Output Board Replacement, Remove USB/Ethernet board: stap 20, afbeelding 1 van 3 Dell 1350cnw Printing Image Output Board Replacement, Remove USB/Ethernet board: stap 20, afbeelding 2 van 3 Dell 1350cnw Printing Image Output Board Replacement, Remove USB/Ethernet board: stap 20, afbeelding 3 van 3
    • Unscrew the 4mm M3 phillips screw holding the USB connector to the rear cover plate.
    • Unscrew the four 5mm M3 phillips screws holding the USB/Ethernet board to the bracket and remove the board from the printer.
  21. Dell 1350cnw Printing Image Output Board Replacement, Unscrew fan bracket: stap 21, afbeelding 1 van 1
    • Unscrew the 5mm M3 phillips screw from the fan bracket.
    • Unhook the retaining clip on the lower right-hand side of the fan bracket to loosen from the printer.
  22. Dell 1350cnw Printing Image Output Board Replacement, Remove fan bracket: stap 22, afbeelding 1 van 3 Dell 1350cnw Printing Image Output Board Replacement, Remove fan bracket: stap 22, afbeelding 2 van 3 Dell 1350cnw Printing Image Output Board Replacement, Remove fan bracket: stap 22, afbeelding 3 van 3
    • De-route the cables from the USB/Ethernet board and remove from the harness on the back of the fan shroud.
    • Pull out the four circled cable connectors to unplug, and de-route the remaining cables from the wiring harness.
    • Lift away the fan/bracket assembly from the printer to remove.
  23. Dell 1350cnw Printing Image Output Board Replacement, De-route cables: stap 23, afbeelding 1 van 3 Dell 1350cnw Printing Image Output Board Replacement, De-route cables: stap 23, afbeelding 2 van 3 Dell 1350cnw Printing Image Output Board Replacement, De-route cables: stap 23, afbeelding 3 van 3
    • Pull out all the indicated cable plugs from the main control board.
    • De-route all the cables from the wiring harness on the side of the printer.
  24. Dell 1350cnw Printing Image Output Board Replacement, Remove side cable bracket: stap 24, afbeelding 1 van 3 Dell 1350cnw Printing Image Output Board Replacement, Remove side cable bracket: stap 24, afbeelding 2 van 3 Dell 1350cnw Printing Image Output Board Replacement, Remove side cable bracket: stap 24, afbeelding 3 van 3
    • Push in the retaining pin on the lower right-hand corner of the lower cable bracket, pulling the bracket out slightly away from the printer.
    • Push down the retaining pin on the top left of the cable bracket, and pull down and out from under the USB/Ethernet board support bracket.
    • Pull the cable bracket away from the printer.
  25. Dell 1350cnw Printing Image Output Board Replacement, Remove cover plate: stap 25, afbeelding 1 van 2 Dell 1350cnw Printing Image Output Board Replacement, Remove cover plate: stap 25, afbeelding 2 van 2
    • Pull out the flat flex cable to remove from the top of the image output board.
    • Unscrew the four 5mm M3 phillips screws at the corners of the image output board over plate.
  26. Dell 1350cnw Printing Image Output Board Replacement, Remove flat flex cables: stap 26, afbeelding 1 van 3 Dell 1350cnw Printing Image Output Board Replacement, Remove flat flex cables: stap 26, afbeelding 2 van 3 Dell 1350cnw Printing Image Output Board Replacement, Remove flat flex cables: stap 26, afbeelding 3 van 3
    • Flip up the retaining bar on each of the five flat flex cable connectors and gently lift out the cable to remove.
Conclusie
Jac
2.728 Reputatie
21 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 15
