Ga door naar hoofdinhoud
Dell 1350cnw Control Panel Replacement
Wat je nodig hebt
  1. Dell 1350cnw Control Panel Replacement, Unclip front top band: stap 1, afbeelding 1 van 2 Dell 1350cnw Control Panel Replacement, Unclip front top band: stap 1, afbeelding 2 van 2
    • Insert prying tool behind each end of the plastic strip. Pry outwards to unclip and pull the ends forwards away from the printer.
    • Note - Unclipping the right-hand end requires opening the toner cover for access.
  2. Dell 1350cnw Control Panel Replacement, Unclip front top band: stap 2, afbeelding 1 van 2 Dell 1350cnw Control Panel Replacement, Unclip front top band: stap 2, afbeelding 2 van 2
    • Insert prying tool between the front band and top cover of the printer, and pry forwards to release the clips holding the top edge in place.
  3. Dell 1350cnw Control Panel Replacement, Remove front top band: stap 3, afbeelding 1 van 1
    • Tilt the top of the front band away from the printer and lift away to remove.
  4. Dell 1350cnw Control Panel Replacement, Remove left-side top band: stap 4, afbeelding 1 van 3 Dell 1350cnw Control Panel Replacement, Remove left-side top band: stap 4, afbeelding 2 van 3 Dell 1350cnw Control Panel Replacement, Remove left-side top band: stap 4, afbeelding 3 van 3
    • Unclip the back end of the plastic trim by prying away from the printer back panel.
    • Pull the trim piece towards the back of the printer.
    • Tilt the top edge away from the printer and lift away to remove.
  5. Dell 1350cnw Control Panel Replacement, Remove control panel module: stap 5, afbeelding 1 van 3 Dell 1350cnw Control Panel Replacement, Remove control panel module: stap 5, afbeelding 2 van 3 Dell 1350cnw Control Panel Replacement, Remove control panel module: stap 5, afbeelding 3 van 3
    • Pry up front edge of the control panel module to unclip.
    • Lift up front edge and pull module forwards slightly to unhook rear edge.
    • Pull out cable connector to unplug the display/ control panel module.
Conclusie
Jac
2.728 Reputatie
21 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 7
Altijd: 19
