Ga door naar hoofdinhoud
Dell Inspiron 15-7569 Battery Replacement
Wat je nodig hebt
  1. Dell   Inspiron  15-7569 Battery Replacement, Back Cover: stap 1, afbeelding 1 van 3 Dell   Inspiron  15-7569 Battery Replacement, Back Cover: stap 1, afbeelding 2 van 3 Dell   Inspiron  15-7569 Battery Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Remove the (10) P58F black screws on the back cover using the Phillips #0 screwdriver.
    • After removing the screws, remove the back cover using a plastic or metal spudger.
  2. Dell   Inspiron  15-7569 Battery Replacement, Battery: stap 2, afbeelding 1 van 3 Dell   Inspiron  15-7569 Battery Replacement, Battery: stap 2, afbeelding 2 van 3 Dell   Inspiron  15-7569 Battery Replacement, Battery: stap 2, afbeelding 3 van 3
    • Unscrew the (4) four screws surrounding the battery with a Phillips #0 screwdriver.
    • Unplug the cord connected to the battery and remove the battery.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Matthew Clements
546 Reputatie
5 handleidingen geschreven
USF Tampa, Team S5-G4, Walkup Fall 2017 Lid van USF Tampa, Team S5-G4, Walkup Fall 2017
USFT-WALKUP-F17S5G4
4 Leden
6 handleidingen geschreven
Één opmerking
Thanks Matthew,
This was a huge help for me. It took just a few minutes, but I spent some time brushing & blowing out the fan & heatsink. Only difference from the instructions is that there are only 2 screws to remove the battery. The other 2 are removed when removing the case. I am grateful for these videos because, otherwise, one is likely to remove extra screws & miss the hidden ones on some products.
Thanks,
Kev
kevs - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 20
Altijd: 6,177
