Ga door naar hoofdinhoud
Definitive Technology W7 Tweeters Replacement
Wat je nodig hebt
  1. Definitive Technology W7 Tweeters Replacement, Access Panel: stap 1, afbeelding 1 van 1
    • Wedge the spudger in any of the four corners of the panel and apply downward pressure on the spudgers handle to pry the panel away from the speaker housing.
    • Repeat this procedure around the perimeter until the panel releases, then lift the panel up by hand.
  2. Definitive Technology W7 Tweeters Replacement: stap 2, afbeelding 1 van 2 Definitive Technology W7 Tweeters Replacement: stap 2, afbeelding 2 van 2
    • Remove the thirteen 5 mm Phillips #0 screws.
    • Once all screws have been removed, gently pull up on the black panel to remove it from the top of the speaker.
  3. Definitive Technology W7 Tweeters Replacement: stap 3, afbeelding 1 van 3 Definitive Technology W7 Tweeters Replacement: stap 3, afbeelding 2 van 3 Definitive Technology W7 Tweeters Replacement: stap 3, afbeelding 3 van 3
    • The gray mesh bag covering the speaker will now be exposed.
    • Flick the switch on the middle of the lock down to loosen the sack.
    • Pull upwards on the locking mechanism to loosen the drawstring. Stop pulling when the mesh bag is loose enough that it can be pulled downwards.
  4. Definitive Technology W7 Tweeters Replacement: stap 4, afbeelding 1 van 2 Definitive Technology W7 Tweeters Replacement: stap 4, afbeelding 2 van 2
    • Remove the four screws on top of the device on each corner with a Phillips #0 screwdriver.
    • Remove the black panel.
  5. Definitive Technology W7 Tweeters Replacement, Tweeters: stap 5, afbeelding 1 van 2 Definitive Technology W7 Tweeters Replacement, Tweeters: stap 5, afbeelding 2 van 2
    • Pull gently on the two red wires to disconnect them individually from the tweeter.
  6. Definitive Technology W7 Tweeters Replacement: stap 6, afbeelding 1 van 1
    • Use the Phillips #0 screwdriver to remove the three black screws attaching the tweeter to the housing.
  7. Definitive Technology W7 Tweeters Replacement: stap 7, afbeelding 1 van 1
    • Gently press down, from the outside of the case, on the tweeter to free it from the speaker case.
    • Ensure that you have an additional hand underneath the tweeter to catch it when it falls from the speaker case.
    • Repeat Steps 1-3 for the other tweeter if necessary.
Conclusie
Brendan Thibault
339 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 2-5, Petersen Fall 2022 Lid van UMass Dartmouth, Team 2-5, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G5
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 179
