Ga door naar hoofdinhoud
Definitive Technology W7 Speaker Replacement
Wat je nodig hebt
  1. Definitive Technology W7 Speaker Replacement, Speaker: stap 1, afbeelding 1 van 1
    • Use the metal spudger to pry off the panel at the top of the device.
    • The top panel has the device logo in the center.
    • Use the flat end of the metal spudger and place it between the gaps of the top panel and slowly pry the panel off.
  2. Definitive Technology W7 Speaker Replacement: stap 2, afbeelding 1 van 1
    • Remove the thirteen Phillips #0 screws.
  3. Definitive Technology W7 Speaker Replacement: stap 3, afbeelding 1 van 1
    • Remove the black panel.
  4. Definitive Technology W7 Speaker Replacement: stap 4, afbeelding 1 van 2 Definitive Technology W7 Speaker Replacement: stap 4, afbeelding 2 van 2
    • After you remove the black panel, you will see that the device is covered with a gray mesh, secured with a drawstring.
    • Flick the switch on the middle of the lock down to loosen the sack.
  5. Definitive Technology W7 Speaker Replacement: stap 5, afbeelding 1 van 1
    • After you have flicked the switch loosen the sack and pull the sack down which will reveal the speaker.
  6. Definitive Technology W7 Speaker Replacement: stap 6, afbeelding 1 van 1
    • Remove the four screws on top of the device on each corner with a Phillips #0 screwdriver.
  7. Definitive Technology W7 Speaker Replacement: stap 7, afbeelding 1 van 1
    • Gently lift the top cover off the device.
  8. Definitive Technology W7 Speaker Replacement: stap 8, afbeelding 1 van 1
    • If you now look inside the device, you will see the speaker which is the large cylinder on the inner side of the device.
  9. Definitive Technology W7 Speaker Replacement: stap 9, afbeelding 1 van 2 Definitive Technology W7 Speaker Replacement: stap 9, afbeelding 2 van 2
    • Remove the four Phillips #0 screws around the speaker holding it in place.
    • Now lay the device on its side with the speaker facing upward, then unscrew the screws around the speaker.
  10. Definitive Technology W7 Speaker Replacement: stap 10, afbeelding 1 van 1
    • Stand the device upright and carefully pull the speaker out of the device with the wires still intact.
  11. Definitive Technology W7 Speaker Replacement: stap 11, afbeelding 1 van 1
    • Now grab the end of the wire connecting the device to the speaker itself.
    • Slowly and carefully pull the wires away from the speaker.
Conclusie
Jamari Brewster
193 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 2-5, Petersen Fall 2022 Lid van UMass Dartmouth, Team 2-5, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G5
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 12
Altijd: 236
