Ga door naar hoofdinhoud
Definitive Technology W7 Motherboard Replacement
Wat je nodig hebt
  1. Definitive Technology W7 Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 3 Definitive Technology W7 Motherboard Replacement, Motherboard: stap 1, afbeelding 2 van 3 Definitive Technology W7 Motherboard Replacement, Motherboard: stap 1, afbeelding 3 van 3
    • Flip the speaker upside down, then use the Phillips #2 screwdriver remove the 4 screws securing the bottom cover.
    • The screw next to the I/O panel will be approximately 20 mm in length. The other screws will be approximately 35 mm in length.
    • Use the metal spudger to remove all rubber feet.
    • Unscrew all four screws from under the rubber feet.
    • These screws will be approximately 35 mm in length.
    • You can now use the prying tool to pry the bottom panel off the speaker.
  2. Definitive Technology W7 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Using a Phillips #2 screwdriver, remove the 5 screws from the motherboard.
    • These screws are approximately 8 mm in length.
  3. Definitive Technology W7 Motherboard Replacement: stap 3, afbeelding 1 van 2 Definitive Technology W7 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Push up the locking tabs on the sides of the ribbon cable connector.
    • Gently pull the ribbon cable out from the connector to remove it.
  4. Definitive Technology W7 Motherboard Replacement: stap 4, afbeelding 1 van 2 Definitive Technology W7 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Tilt the motherboard outwards from the speaker.
    • Remove all five connectors from the motherboard.
    • Remove the motherboard from the speaker.
  5. Definitive Technology W7 Motherboard Replacement: stap 5, afbeelding 1 van 2 Definitive Technology W7 Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Using the Phillips #2 screwdriver, remove the three screws from the network card.
    • These screws are approximately 8mm in length.
    • Remove the network card from the motherboard.
Conclusie
Magnus Maillet
171 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 2-5, Petersen Fall 2022 Lid van UMass Dartmouth, Team 2-5, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G5
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 256
