Ga door naar hoofdinhoud
Decorative Light Fixture Lightbulb Replacement
Wat je nodig hebt
  1. Decorative Light Fixture Lightbulb Replacement, Lightbulb: stap 1, afbeelding 1 van 1
    • WARNING: Before beginning this guide, turn off the power from the circuit breaker, and turn off any light switches that provide power to the item you’re working on.
    • Position a sturdy ladder beneath the light fixture.
  2. Decorative Light Fixture Lightbulb Replacement: stap 2, afbeelding 1 van 2 Decorative Light Fixture Lightbulb Replacement: stap 2, afbeelding 2 van 2
    • Hold onto the fixture with one hand, and use the screwdriver to start unscrewing the fixture with your other hand.
    • If possible, have someone else hold the fixture for you.
    • Caution: Be careful not to drop the fixture. Broken glass can be very dangerous.
  3. Decorative Light Fixture Lightbulb Replacement: stap 3, afbeelding 1 van 1
    • Place the fixture and any loose screws off to the side.
  4. Decorative Light Fixture Lightbulb Replacement: stap 4, afbeelding 1 van 2 Decorative Light Fixture Lightbulb Replacement: stap 4, afbeelding 2 van 2
    • Unscrew the lightbulb from the fixture.
  5. Decorative Light Fixture Lightbulb Replacement: stap 5, afbeelding 1 van 1
    • Check to make sure that your replacement lightbulb matches the necessary type for the fixture.
  6. Decorative Light Fixture Lightbulb Replacement: stap 6, afbeelding 1 van 2 Decorative Light Fixture Lightbulb Replacement: stap 6, afbeelding 2 van 2
    • Re-screw the lightbulb into the fixture.
  7. Decorative Light Fixture Lightbulb Replacement: stap 7, afbeelding 1 van 2 Decorative Light Fixture Lightbulb Replacement: stap 7, afbeelding 2 van 2
    • Hold onto the fixture, and screw it back in with the screwdriver.
Eindstreep
Jordan Parry
145 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 269
