Ga door naar hoofdinhoud
DeWalt_D26451 Brake Replacement
Wat je nodig hebt
  1. DeWalt_D26451 Brake Replacement, Pad: stap 1, afbeelding 1 van 3 DeWalt_D26451 Brake Replacement, Pad: stap 1, afbeelding 2 van 3 DeWalt_D26451 Brake Replacement, Pad: stap 1, afbeelding 3 van 3
    • Please wear safety glasses while completing this replacement guide.
    • Insert the 60 mm extension into the screw driver which has the t15 torx bit installed in order to make a t-handle grip.
    • Turn the screwdriver counter-clockwise to loosen all three screws in the disc pad.
  2. DeWalt_D26451 Brake Replacement: stap 2, afbeelding 1 van 2 DeWalt_D26451 Brake Replacement: stap 2, afbeelding 2 van 2
    • Turn the disc pad over and remove the loosened screws.
    • When the screws are removed, the disc pad will come off of the sander.
  3. DeWalt_D26451 Brake Replacement, Brake: stap 3, afbeelding 1 van 1
    • Please wear safety glasses while completing this repair guide.
    • Loosen and remove the three screws on the bottom of the sander that holds the disc pad to the bottom of the sander.
  4. DeWalt_D26451 Brake Replacement: stap 4, afbeelding 1 van 1
    • After the T20 torx bolts have been removed, remove the disc pad from the sander.
  5. DeWalt_D26451 Brake Replacement: stap 5, afbeelding 1 van 1
    • When the disc pad is removed, the brake is located directly under it. Remove the brake from the sander.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 21
Altijd: 2,084
