Ga door naar hoofdinhoud
DeWalt DWE4011 Carbon Brushes Replacement
Wat je nodig hebt
  1. DeWalt DWE4011 Carbon Brushes Replacement, Carbon Brushes: stap 1, afbeelding 1 van 1
    • Turn to the bottom of the device and remove the 5/8" (17mm) T15 Torx screw shown using a T15 Torx Screwdriver.
  2. DeWalt DWE4011 Carbon Brushes Replacement: stap 2, afbeelding 1 van 1
    • Remove the outer casing to expose the brushes by pulling the end handle away from the field case.
  3. DeWalt DWE4011 Carbon Brushes Replacement: stap 3, afbeelding 1 van 2 DeWalt DWE4011 Carbon Brushes Replacement: stap 3, afbeelding 2 van 2
    • Locate both carbon brushes on either side of the device.
  4. DeWalt DWE4011 Carbon Brushes Replacement: stap 4, afbeelding 1 van 1
    • Using the iFixit opening tool, remove the female terminal connecting the carbon brush wire to the male terminal.
  5. DeWalt DWE4011 Carbon Brushes Replacement: stap 5, afbeelding 1 van 1
    • Keeping a tight hold the entire time, move the spring covering the carbon brush so that it is behind the male terminal.
    • Be extremely careful, as the spring is tightly coiled and can easily get away from you.
  6. DeWalt DWE4011 Carbon Brushes Replacement: stap 6, afbeelding 1 van 2 DeWalt DWE4011 Carbon Brushes Replacement: stap 6, afbeelding 2 van 2
    • Taking hold of the wire you removed in step 4, gently slide the carbon brush out of its casing and remove it from the device.
    • Flip over the device to reveal the second carbon brush, and repeat steps 4 through 6 on the other side.
Conclusie
Congratulations! To put your device back together, simply reverse the above steps.
Kiera Sloan
145 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 32
Altijd: 1,366
