Inleiding
If the drill is on but not spinning, then the motor should be replaced.
Wat je nodig hebt
Remove seven 21 mm Torx T15 screws.
Remove one 18 mm Torx T10 screw.
After removing all screws, lift up the top yellow cover.
Één andere persoon heeft deze handleiding voltooid.
