Ga door naar hoofdinhoud
DeWalt DW936 Saw Blade Replacement
  1. DeWalt DW936 Saw Blade Replacement, Saw Blade: stap 1, afbeelding 1 van 1
    • Take out the Allen Key that is located on the front of the saw below the smooth control handle on the top of the saw.
  2. DeWalt DW936 Saw Blade Replacement: stap 2, afbeelding 1 van 1
    • Use the Allen Key to replace to loosen the bolt where the center of the saw is/would be.
  3. DeWalt DW936 Saw Blade Replacement: stap 3, afbeelding 1 van 1
    • Remove the circular nut that is used to hold the saw blade in place. It slide right off.
  4. DeWalt DW936 Saw Blade Replacement: stap 4, afbeelding 1 van 1
    • Lift up the plastic cover on the bottom to expose the bottom slot on the saw.
  5. DeWalt DW936 Saw Blade Replacement: stap 5, afbeelding 1 van 1
    • Place blade on the peg in the middle of the saw. The peg has two flat sides as does the saw hole to prevent slipping when spinning.
Conclusie
Scott Weinhardt
603 Reputatie
5 handleidingen geschreven
Cal Poly, Team 8-2, Banghart Winter 2017 Lid van Cal Poly, Team 8-2, Banghart Winter 2017
CPSU-BANGHART-W17S8G2
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 30
Altijd: 2,828
