Ga door naar hoofdinhoud
DeWalt DW936 Plastic Cover Replacement
Wat je nodig hebt
  1. DeWalt DW936 Plastic Cover Replacement, Plastic Cover: stap 1, afbeelding 1 van 1
    • Use a T-20 hexhead screw to unscrew 4 hexagonal screws surrounding the base of the black air filter. The screws are on the yellow portion.
  2. DeWalt DW936 Plastic Cover Replacement: stap 2, afbeelding 1 van 1
    • Use a T-15 hexhead screw to unscrew 5 hexagonal screws. These screws are located on the opposite side of the saw from previous step.
  3. DeWalt DW936 Plastic Cover Replacement: stap 3, afbeelding 1 van 1
    • Remove Allen Key.
  4. DeWalt DW936 Plastic Cover Replacement: stap 4, afbeelding 1 van 1
    • Unscrew the black plastic knob underneath the trigger.
  5. DeWalt DW936 Plastic Cover Replacement: stap 5, afbeelding 1 van 1
    • Grab hold of the black air filter portion and pull off.
  6. DeWalt DW936 Plastic Cover Replacement: stap 6, afbeelding 1 van 1
    • This is what the inside of the saw looks like.
Conclusie
Scott Weinhardt
603 Reputatie
5 handleidingen geschreven
Cal Poly, Team 8-2, Banghart Winter 2017 Lid van Cal Poly, Team 8-2, Banghart Winter 2017
CPSU-BANGHART-W17S8G2
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 366
