Ga door naar hoofdinhoud
DeWalt DW936 Boot Replacement
Wat je nodig hebt
  1. DeWalt DW936 Boot Replacement, Plastic Cover: stap 1, afbeelding 1 van 1
    • Use a T-20 hexhead screw to unscrew 4 hexagonal screws surrounding the base of the black air filter. The screws are on the yellow portion.
  2. DeWalt DW936 Boot Replacement: stap 2, afbeelding 1 van 1
    • Use a T-15 hexhead screw to unscrew 5 hexagonal screws. These screws are located on the opposite side of the saw from previous step.
  3. DeWalt DW936 Boot Replacement: stap 3, afbeelding 1 van 1
    • Remove Allen Key.
  4. DeWalt DW936 Boot Replacement: stap 4, afbeelding 1 van 1
    • Unscrew the black plastic knob underneath the trigger.
  5. DeWalt DW936 Boot Replacement: stap 5, afbeelding 1 van 1
    • Grab hold of the black air filter portion and pull off.
  6. DeWalt DW936 Boot Replacement: stap 6, afbeelding 1 van 1
    • This is what the inside of the saw looks like.
  7. DeWalt DW936 Boot Replacement, Boot: stap 7, afbeelding 1 van 1
    • Use a T-15 hex head screw to unscrew the four screws located around the outside of the motor.
  8. DeWalt DW936 Boot Replacement: stap 8, afbeelding 1 van 1
    • Using an H 4.0 hex head screw, unscrew the bolt located right above the boot that is next to the motor of the saw.
  9. DeWalt DW936 Boot Replacement: stap 9, afbeelding 1 van 1
    • Pull the blade away from the body of the saw causing the blade and boot to detach.
  10. DeWalt DW936 Boot Replacement: stap 10, afbeelding 1 van 1
    • Pull the boot downwards away from the blade to detach it.
Conclusie
Scott Weinhardt
603 Reputatie
5 handleidingen geschreven
Cal Poly, Team 8-2, Banghart Winter 2017 Lid van Cal Poly, Team 8-2, Banghart Winter 2017
CPSU-BANGHART-W17S8G2
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 15
Altijd: 483
