Ga door naar hoofdinhoud
DeWalt DW920 Motor Replacement
Wat je nodig hebt
  1. DeWalt DW920 Motor Replacement, Disassembly: stap 1, afbeelding 1 van 1
    • Using an H-5.0 bit driver remove the four T-10 Torx screws.
  2. DeWalt DW920 Motor Replacement: stap 2, afbeelding 1 van 1
    • Use 2 H-5.0 bit drivers to take out the main bolt and head.
    • There will be blue locktite on the tread.
  3. DeWalt DW920 Motor Replacement: stap 3, afbeelding 1 van 1
    • Carefully remove the two halves of the handle.
  4. DeWalt DW920 Motor Replacement, Motor: stap 4, afbeelding 1 van 1
    • Gently lift the motor and trigger mechanism out from the frame of the drill.
  5. DeWalt DW920 Motor Replacement: stap 5, afbeelding 1 van 1
    • Locate where the motor assembly is attached to the trigger mechanism and carefully detach the wires at their solder points.
    • Mark where the two cables was connected using a masking tape or similar.
  6. DeWalt DW920 Motor Replacement: stap 6, afbeelding 1 van 1
    • Solder the new motor assembly wires to the trigger mechanism in the same fashion that the old motor was.
    • Remember to check the markers from the step before and solder the cables on the right place.
Conclusie
Stephen Rada
433 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 8-2, Botvin Spring 2016 Lid van UMass Dartmouth, Team 8-2, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G2
2 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 12
Altijd: 806
