Ga door naar hoofdinhoud
DeWalt DW920 Lock Switch Replacement
Wat je nodig hebt
  1. DeWalt DW920 Lock Switch Replacement, Disassembly: stap 1, afbeelding 1 van 1
    • Using an H-5.0 bit driver remove the four T-10 Torx screws.
  2. DeWalt DW920 Lock Switch Replacement: stap 2, afbeelding 1 van 1
    • Use 2 H-5.0 bit drivers to take out the main bolt and head.
    • There will be blue locktite on the tread.
  3. DeWalt DW920 Lock Switch Replacement: stap 3, afbeelding 1 van 1
    • Carefully remove the two halves of the handle.
  4. DeWalt DW920 Lock Switch Replacement, Lock Switch: stap 4, afbeelding 1 van 1
    • Locate the switch on the top of the drill right before the bending joint.
  5. DeWalt DW920 Lock Switch Replacement: stap 5, afbeelding 1 van 2 DeWalt DW920 Lock Switch Replacement: stap 5, afbeelding 2 van 2
    • Firmly grasp the switch with two fingers and lift it straight up. The spring should remain attached to the switch during this process.
    • It should lift right out. If it is caught on anything do not force it out.
Conclusie
Stephen Rada
433 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 8-2, Botvin Spring 2016 Lid van UMass Dartmouth, Team 8-2, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G2
2 Leden
6 handleidingen geschreven
Één opmerking
This guide was descriptive and easy to follow. Good job!
DankMemerino - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 286
