Inleiding
This guide will show the replacement of the trigger and battery terminal system. Please note that they cannot be replaced separately, and the unit cannot be disassembled.
Wat je nodig hebt
Remove the M3x16mm T10 screw from the back of the grip. Keep it separate from the rest of the grip screws
Remove the six M3.63x19 T15 screws from the grip.
Take note of the position of the battery tension spring and safety switch before removal.
Lift the trigger assembly out of the grip.
