Ga door naar hoofdinhoud
DeWalt DCS380 Motor Armature Replacement
Wat je nodig hebt
  1. DeWalt DCS380 Motor Armature Replacement, Removing shoe and boot.: stap 1, afbeelding 1 van 1
    • Remove the battery before disassembly.
    • Remove the shoe by pressing the yellow button on the left side of the hand grip.
  2. DeWalt DCS380 Motor Armature Replacement: stap 2, afbeelding 1 van 2 DeWalt DCS380 Motor Armature Replacement: stap 2, afbeelding 2 van 2
    • Remove the two M8x18mm T20 bolts from the front plate.
  3. DeWalt DCS380 Motor Armature Replacement: stap 3, afbeelding 1 van 1
    • Pull the front of the grip while holding the saw body in place.
  4. DeWalt DCS380 Motor Armature Replacement, DeWalt DCS380 Grip Disassembly: stap 4, afbeelding 1 van 2 DeWalt DCS380 Motor Armature Replacement, DeWalt DCS380 Grip Disassembly: stap 4, afbeelding 2 van 2
    • Remove the battery before dissasembly.
    • Remove the M3x16mm T10 screw from the back of the grip. Keep it separate from the rest of the grip screws
    • Remove the six M3.63x19 T15 screws from the grip.
  5. DeWalt DCS380 Motor Armature Replacement: stap 5, afbeelding 1 van 3 DeWalt DCS380 Motor Armature Replacement: stap 5, afbeelding 2 van 3 DeWalt DCS380 Motor Armature Replacement: stap 5, afbeelding 3 van 3
    • Remove the top half of the grip.
    • Turn the saw over and locate the power connectors to the motor.
    • Use needle nose pliers to remove the spade connectors. Take care not to grab the wires on removal, only the end of the spade terminal.
    • Note the polarity for the power connectors and be sure they are not reversed on reassembly.
  6. DeWalt DCS380 Motor Armature Replacement, Motor Armature: stap 6, afbeelding 1 van 2 DeWalt DCS380 Motor Armature Replacement, Motor Armature: stap 6, afbeelding 2 van 2
    • Remove three M8x18 T20 bolts from the back of the gearbox.
    • Pull the motor case off of the armature.
  7. DeWalt DCS380 Motor Armature Replacement: stap 7, afbeelding 1 van 2 DeWalt DCS380 Motor Armature Replacement: stap 7, afbeelding 2 van 2
    • Remove two M8x12mm T20 bolts from the bearing retainer.
    • Pull the shaft out of the gearbox.
    • Please note, the brushes will need to be disengaged to reassemble the motor. See the end of the Motor Brush replacement section of this guide for details.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 25
Altijd: 1,006
