Inleiding
This guide will take you through removing the back panel assembly and disconnecting the power cable from the inner electric components.
Wat je nodig hebt
Using the T-15 screwdriver, remove the four 22-mm torx screws holding the back panel in place.
Locate the red switch box.
Using the J-10 screwdriver, unscrew the screws and detach the wires.
Bijna klaar!
Conclusie
