Inleiding
This guide will walk you through replacing the plastic arms holding the brushes in place. These are both located at the base of the brush motor and are required for electrical connection.
Wat je nodig hebt
Using the T-15 screwdriver, remove the four 22-mm torx screws holding the back panel in place.
Één andere persoon heeft deze handleiding voltooid.
