Ga door naar hoofdinhoud
Datawind Ubislate 7ci Speaker Replacement
Wat je nodig hebt
  1. Datawind Ubislate 7ci Speaker Replacement, Finding a workspace: stap 1, afbeelding 1 van 1
    • Be sure to repair your device on a clean surface so you are less likely to lose small parts.
  2. Datawind Ubislate 7ci Speaker Replacement, Pry open your tablet: stap 2, afbeelding 1 van 2 Datawind Ubislate 7ci Speaker Replacement, Pry open your tablet: stap 2, afbeelding 2 van 2
    • Run your prying tool along the front edge of the device to pop off the front cover.
    • Once the halves are separated, your device should look like this.
    • (HINT: be careful of the device's small wiring when separating the two halves)
  3. Datawind Ubislate 7ci Speaker Replacement, Removing the speaker: stap 3, afbeelding 1 van 1
    • Use your prying tool to pop the speaker out from its housing.
  4. Datawind Ubislate 7ci Speaker Replacement, Detach from contact points: stap 4, afbeelding 1 van 1
    • Use a soldering iron to remove the speaker from its contact points.
  5. Datawind Ubislate 7ci Speaker Replacement, Attaching replacement to contact points: stap 5, afbeelding 1 van 1
    • Solder your new speaker to the same contact points as before.
  6. Datawind Ubislate 7ci Speaker Replacement, Housing the replacement speaker: stap 6, afbeelding 1 van 1
    • Apply a small amount of adhesive to the new speaker, and place it into the housing on the back panel.
  7. Datawind Ubislate 7ci Speaker Replacement, Putting your tablet back together: stap 7, afbeelding 1 van 2 Datawind Ubislate 7ci Speaker Replacement, Putting your tablet back together: stap 7, afbeelding 2 van 2
    • Put the two halves back together.
    • Push down on the edges until you hear them click into place.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Mekides
40 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014 Lid van UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G3
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 276
