Ga door naar hoofdinhoud
Datawind Ubislate 7ci Rear Facing Camera Replacement
Wat je nodig hebt
  1. Datawind Ubislate 7ci Rear Facing Camera Replacement, Finding a work space: stap 1, afbeelding 1 van 1
    • Be sure to repair your device on a clean surface so you are less likely to lose small parts.
  2. Datawind Ubislate 7ci Rear Facing Camera Replacement, Pry open your tablet: stap 2, afbeelding 1 van 2 Datawind Ubislate 7ci Rear Facing Camera Replacement, Pry open your tablet: stap 2, afbeelding 2 van 2
    • Run your prying tool along the front edge of the device to pop off the front cover.
    • Once the halves are separated your device should look like this.
    • (HINT: be careful of the device's small wiring when separating the two halves.)
  3. Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the tape around the camera: stap 3, afbeelding 1 van 2 Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the tape around the camera: stap 3, afbeelding 2 van 2
    • Remove the black tape that is circled.
    • The camera is circled in this picture.
  4. Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the camera: stap 4, afbeelding 1 van 2 Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the camera: stap 4, afbeelding 2 van 2
    • Carefully remove the camera from its housing.
  5. Datawind Ubislate 7ci Rear Facing Camera Replacement, Inserting the Replacement Camera: stap 5, afbeelding 1 van 2 Datawind Ubislate 7ci Rear Facing Camera Replacement, Inserting the Replacement Camera: stap 5, afbeelding 2 van 2
    • Slide the new camera into its housing carefully.
    • it should look like the second picture when you are finished
  6. Datawind Ubislate 7ci Rear Facing Camera Replacement, Closing the Tablet: stap 6, afbeelding 1 van 1
    • Press the back cover of the tablet on firmly until it clicks
Conclusie
Mekides
40 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014 Lid van UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G3
3 Leden
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 316
